elamp
Newbie level 1
- Joined
- Apr 27, 2012
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Minneapolis,MN
- Activity points
- 1,294
Hello All,
I am trying to design/build a battery powered LED lamp that is solar charged. My electronics background is fairly basic. The specific components I would like to use are:
1. Four AA 2500mah NiMh batteries. I may use four "C" size 5000mah for increased operating time if needed.
2. A one watt LED 3-3.4v 330ma max( I will be running it at 200ma to extend battery run time. I would like to get 6-10 hours if possible) and running it at 200ma it outputs plenty of lumens for this project.
3. One Solar PV panel. Output: 6+ vdc @ 580ma
I am looking for help with some kind of over/under voltage cut out to protect the battery pack. Parameters are:
1. under voltage cut out approximately 4.4-4.5v (1.1-1.125v per cell)
2. overvoltage cut out at 5.72v (1.43v per cell)
3. minimum amount of components and any IC's preferably DIP style to enable unskilled persons to be able to handle and solder them easily. These will be assembled in developing countries.
We have had great success with a solar cellphone charger using a LDO regulator to keep the output at 5 volts. Now I'm looking at a LED lamp system.
Any help would be appreciated
