need 12V ~ 10A power supply
engraxate
Member level 3
Member level 3
12v 10a power supply
I have to make 12V ~ 10A power supply, but I have no idea how to do that.
Any idea are welcome.
thanks
power supply 12v 10a
My choice would be to use 10 1.5 amp LM 317 adjustable + regulator`s
Well heatsinked set to deliver 12v. Use a 0.3 ohm resistor on each output to maintain equil current flow through each regulator.
Ensure that your transformer / rectifiers / smothing are capable of suporting 10 amps current flow.
12v power supply 10a
Loot at www.st.com and search "L4970". I use its to create a very good switching power supply up to 10A
thanks
10a power supply
Do you need a regulated supply or an unregulated one?
A cheap way of getting an high power unregulated supply is to buy a car battery charger - they are often cheaper than the cost of a transformer by itself! They are normally rectified but not smoothed, so you need to add a large capacitor on the output.
12v 10a transformer
You can modified the 5v output of PC Power supply.
Which components ?
- Switching transformator.
- Rectifiers, inductance and capacitors of secondary side of trf.
- feedback unit.
12v 10a psu
Try this link...
[h**p://control.gsnu.ac.kr/~f007dan/cicuit/homepage.htm#menu]
I looked at it and I think you might be able to get what you want here. Good luck. <ckd>
10a 12v power supply
Check the ARRL manual for what you want.
Bye.
power supply 12v/10a circuits
modified the PC Power supply
h**p://www.qsl.net/vk4ba/projects/index.html
LaTeX Commands Quick-Menu:
