NC-Verilog hdl.var problem?
davyzhu
Advanced Member level 1
oriental
hdl.var
Hi all,
I am a NC-Verilog newbie and confused with NC-Verilog's file.
In cds.lib, map logical lib name to physical location
DEFINE ic_lib /lsi_lib
Why map again in hdl.var?
DEFINE WORK worklib
DEFINE LIB_MAP (myfile.v => mylib, ./cell_lib => techlib, + => worklib)
Does "myfile.v => mylib" means compile myfile.v to mylib?
And what's "+ => worklib" mean in LIB_MAP?
Best regards,
Davy
aji_vlsi
Advanced Member level 2
Bangalore, India
ncvlog hdl.var worklib
Hi again,
davyzhu said:
Hi all,
Yes, cds.lib is for defining LIBRARIES (as the extension says).
hdl.var --> Defines HDL Variables such as:
  • WORK
    Tool options (NCVHDLOPTS, NCELABOPTS, NCVLOGOPTS, NCSIMOPTS etc.)
    Files to library maps
Read that from a VHDL perspective - one can have several libraries and have different design units compiled to different libraries. For that you need a mechanism to associate which files go to which library.
DEFINE WORK worklib
This specifies a default WORK for you. Again little VHDL centric - VHDL needs a WORK to compile any thing. One can override this with command line -work option. Note that the "worklib" above is a LOGICAL name and that must be defined by a cds.lib to a physical directory.
Slowly becoming a NC expert you are :)
Best regards,
Davy
Any other file goes there - i..e like "*" in regular expressions, default in a Verilog case statement etc.
HTH
Ajeetha, CVC
www.noveldv.com
Reactions: imike
    davyzhu
    imike
