cberry
- Joined
- May 13, 2010
- Messages
- 5
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Dallas, Texas
- Activity points
- 1,325
I'm trying to implement a simple FPGA controlled pulldown to control another device (pull 15V/10KΩ signal down to ground to disable device). However, I'm getting 0.5mA to 1.5mA oscillations of leakage current through my MOSFET even when the gate and source are connected together (and to ground). The stated maximum on the datasheet is 0.5uA with a breakdown voltage of 50V.
I've tried a couple of models and resoldered about 15 new fets. I've also tried putting Zeners on the gate and source to limit the voltages to 5V and 20V respectively. When soldering I've had extremely fast touches (0.5s or less) on the leads to try and prevent thermal damage. I've seen that the MOSFET will sometimes work for a minute and then the leakage oscillations start.
What could be causing / allowing the current to leak through?
Thanks,
CB
Thanks,
CB
