righteous
Full Member level 2
Q1, Q3 and M1 (referring to schematic) are on the purple round board, I assume, but there are too many SOT packages for your schematic (which I guess would have 6 FETs) and no TO packages for the push pull stage. Can you tell what exactly is in the mentioned board?
Please see attached schematic.
View attachment bldc-driver.pdf
The "OUT" signal is above the threshold of the FETs, so yes, you will have shoot-through if there are FETs in half bridge config.
Yes, and I can't measure the signal while there is power on the driver pcb.
So you are actually using driver ICs ? Not the discrete one in post #1 ?
The discrete one as in post #1
