Must capacitors used with MAX232 devices be polarized ?
dxpwny
Full Member level 1
I saw a previous question similar to this, though I don't think it addressed polarity.
I have some tantalum caps which don't appear to be polarized - are they fine to use with the MAX232 type devices ?
Unlikely. Either they are not tantalum electrolyte type or you didn't yet understand the marking.
Appart from this point you can always use non-polarized capacitors (e.g. ceramic or film) in place of polarized.
I assume it must not be - there is no +/-. How else might polarity be noted ? Marking on one side reads "102 AFN", then "270 AIJ" on the other.
Why do you have a series cap in RS232? unless this is for a charge pump IC then I understand. But these typically use 0.1uF
FYI it is ok to have 10% of rated voltage in reverse on e-caps.
Sorry - should have been clearer - yes it is for the charge pump.
Electrolytic capacitors don't necessarily have a plus sign, a bar marking the anode terminal is quite common.
102 means usually 1 nF, if so this won't be a tantalum electrolytic capacitor.
Standard MAX232 requires 1 µF charge pump capacitors.
