sarathbc2002
Newbie level 3
multi-cycle pipeline
Multicycle vs Pipeline
I am confused in choosing between Multicycle or Pipeline in implementing
a chunk of logic ..I have explained the 2 possible scenarios below
PIPELINE
Below c1 through c4 are blocks of combinational logic.
"|" is a register:
A pipeline separates multiple states of combinational
logic with registers
Each block plus register will perform at 10 ns clock boundaries.
I constrain the design for 10 ns clock
in -- | c1 | c2 | c3 | c4 | -- out
MULTICYCLE
In Multicycle path I remove the internal registers
in -- | c1 c2 c3 c4 | -- out
Since the pipelined design ran at 10 ns, this
one should be able to run at 40 ns. So I constrain it with
a multicycle of 4
Are these 2 implementations functionally same ??
What is the throughput in the above 2 cases ?
In the Pipelined approach apart from the initial latency ,result is got
once every clock cycle .
In the multicyle approach I have the result once every several clock cycles
Can the throughput of multicyle be made equal to that of pipelined approach
if it satisfies certain hold constraints
PIPELINE
"|" is a register:
MULTICYCLE
a multicycle of 4
