multibuses affectation in vhdl
ramzitligue
Member level 1
multibuses in vhdl
hi,i want to do a multibuses affectation but it didn't work
this is my program:
TYPE data_port IS RECORD
en : STD_LOGIC;
write : STD_LOGIC;
internal : STD_LOGIC;
sel_dcache : STD_LOGIC;
sel_ram : STD_LOGIC;
sel_ext : STD_LOGIC;
addr : data_addr;
data : data_bus;
END RECORD;
entity multi is
in : inout data_port;
out1 : inout data_port;
out2 : inout data_port;
switch : in std_logic
architecture rtl of multi is
process(switch)
begin
if switch='1' then
out1<=in;
else
out2<=in;
end if;
end process;
end rtl;
what can i do ?thanks.
FvM
Super Moderator
Staff member
Bochum, Germany
Re: multibuses in vhdl
what can i do ?
Keep VHDL syntax rules.
E.g.:
- Add necessary library definitions.
- Define a package for the record type.
library ieee;
use ieee.std_logic_1164.all;
package defs is
-- your type definitions used in the below entity port
end package defs;
library ieee;
library work;
use work.defs.all;
entity multi is
end;
architecture rtl of test is
end rtl;
There are some additional detail errors, you'll be aware of, when the overall syntax is correct.
ramzitligue
Member level 1
hi,
thanks for responding, and sorry because i don't mention that i already put all library and package.my problem is that my program didn't work when i simulated it on modelsim.
FvM
Super Moderator
Staff member
Bochum, Germany
multibuses in vhdl
In other words, your saying, that the various obvious syntax errors in your post are just arbitrary omissions. How can we know, what's else missing?
Also didn't work is still maximum unclearness... You may want to assemble an informative posting to get effective help.
sajal1975
Full Member level 2
hlp me to use multibuses
