mspgeek
Newbie level 1
Hello all, what I am trying to do is that to observe the exact time intervals for the watchdog timer in MSP430, but no matter which clock I choose I can't get the same results I calculated by hand.
for example by this interrupt I expect LED to turn off 2.6 seconds just after the button is pushed but takes more than that, I tried some other examples using the submain clock it is same again I can't get theoretical results. What may cause this, or is there something else I should take into consideration, thank you?
Code C - [expand] 1 2 3 4 5 6 7 8 9 #pragma vector = PORT1_VECTOR __interrupt void PORT1_ISR(void){ P1OUT = LED; BCSCTL3 |= LFXT1S_2; //Auxiliry Clock is chosen which is 12kHz WDTCTL = WDT_ARST_1000; //According to Msp430 instructions for ACLK(32 KHZ) WDT_ARST_1000(1000ms) so for 12kHz it must be 2.6 seconds P1IFG = 0x00; }
