amit_dhanawade
Junior Member level 1
Hello,
I want to interfacing MPU6050 I2C gyroscope sensor to lpc2138. I am able to read sensor powered on, but as soon as I move senor a little it hangs up. I don't want to use interrupt so I have disabled it...
Please let me know if I am missing some thing, I searched a lot for tutorial on this but there all is with Arduino and I want it to interface with LPC2138.
Below is code done in Keil...
#include <LPC214x.h>
#include <stdio.h> /* standard I/O .h-file */
//#include <ctype.h> /* character functions */
#include <string.h> /* string and memory functions */
#include "font.h"
#include "glcd.h"
#include "uart.h"
#include "Typedefs.h"
#include "Timer.h"
#include "Target.h"
#include "keypad.h"
#include "adc.h"
#include "i2c.h"
#include "Declarations.h"
#include "rtc.h"
#include "EEPROM.h"
#include "key.h"
#include "R_Sensors.h"
char key1=0;
short i;
float ldr_val;
char GYRO_XOUT_H;
char GYRO_XOUT_L;
char GYRO_YOUT_H;
char GYRO_YOUT_L;
char GYRO_ZOUT_H;
char GYRO_ZOUT_L;
int xl,yl,zl,xh,yh,zh,st;
int GYRO_XOUT_OFFSET_1000SUM;
int GYRO_YOUT_OFFSET_1000SUM;
int GYRO_ZOUT_OFFSET_1000SUM;
int GYRO_XOUT_OFFSET;
int GYRO_YOUT_OFFSET;
int GYRO_ZOUT_OFFSET;//ldr_val[0]=0;
unsigned char read_gyro(char address)
unsigned char read;
InitI2C();
// Delay(1);
SendI2CAddress(0xD0);
// Delay(1);
WriteI2C(address);
// Delay(1);
InitI2C();
// Delay(1);
SendI2CAddress(0xD1);
// Delay(1);
read = ReadI2C();
// Delay(1);
StopI2C();
// Delay(1);
return (read);
void write_gyro(unsigned char address,unsigned char data)
InitI2C();
// Delay(1);
// Delay(1);
WriteI2C(address);
// Delay(1);
WriteI2C(data);
// Delay(1);
StopI2C();
// Delay(1);
void configure_gyro(void)
// write_gyro(SMPLRT_DIV, 0x07);
// write_gyro(CONFIG, 0x00);
// write_gyro(GYRO_CONFIG, 0x08);
// write_gyro(ACCEL_CONFIG, 0x08);
write_gyro(0x6B, 0x10);
Delay(100);
// write_gyro(PWR_MGMT_2, 0x00);
// write_gyro(SIGNAL_PATH_RESET, 0x00);
//Reset sensor signal paths
write_gyro(0x68, 0x07 );
Delay(10);
//Disables FIFO, AUX I2C, FIFO and I2C reset bits to 0
write_gyro(0x6A, 0x07 );
Delay(10);
//Motion detection control
write_gyro(0x69, 0x20 );
Delay(10);
write_gyro(0x6A, 0x40 );
Delay(10);
//Disable sensor output to FIFO buffer
write_gyro(0x23, 0xF8 );
Delay(10);
//Setup INT pin and AUX I2C pass through
write_gyro(0x37, 0x00 );
Delay(10);
//Enable data ready inerrupt
write_gyro(0x38, 0x00 );
Delay(10);
//Sets clock source to gyro reference w/ PLL
write_gyro(0x6B, 0x00 );
Delay(10);
//Disable accel self tests, scale of +-2g, no DHPF
write_gyro(0x1C, 0x00 );
Delay(10);
//Sets sample rate to 8000/1+7 = 1000Hz
write_gyro(0x19, 0x07 );
Delay(10);
//Disable FSync, 256Hz DLPF
write_gyro(0x1A, 0x00 );
Delay(10);
//Disable gyro self tests, scale of 500 degrees/s
write_gyro(0x1B, 0x08 );
Delay(10);
//Freefall threshold of |0mg|
write_gyro(0x1D, 0x00 );
Delay(10);
//Freefall duration limit of 0
write_gyro(0x1E, 0x00 );
Delay(10);
//Motion threshold of 0mg
write_gyro(0x1F, 0x00 );
Delay(10);
//Motion duration of 0s
write_gyro(0x20, 0x00 );
Delay(10);
//Zero motion threshold
write_gyro(0x21, 0x00 );
Delay(10);
//Zero motion duration threshold
write_gyro(0x22, 0x00 );
Delay(10);
//determines which sensor measurements are loaded into the FIFO buffer
Delay(10);
//AUX I2C setup
//Sets AUX I2C to single master control, plus other config
write_gyro(0x24, 0x00 );
Delay(10);
//Setup AUX I2C slaves
write_gyro(0x25, 0x00 );
Delay(10);
write_gyro(0x26, 0x00 );
Delay(10);
write_gyro(0x27, 0x00 );
Delay(10);
write_gyro(0x28, 0x00 );
Delay(10);
write_gyro(0x29, 0x00 );
Delay(10);
write_gyro(0x2A, 0x00 );
Delay(10);
write_gyro(0x2B, 0x00 );
Delay(10);
write_gyro(0x2C, 0x00 );
Delay(10);
write_gyro(0x2D, 0x00 );
Delay(10);
write_gyro(0x2E, 0x00 );
Delay(10);
write_gyro(0x2F, 0x00 );
Delay(10);
write_gyro(0x30, 0x00 );
Delay(10);
write_gyro(0x31, 0x00 );
Delay(10);
write_gyro(0x32, 0x00 );
Delay(10);
write_gyro(0x33, 0x00 );
Delay(10);
write_gyro(0x34, 0x00 );
Delay(10);
write_gyro(0x35, 0x00 );
Delay(10);
//MPU6050_RA_I2C_MST_STATUS //Read-only
//Slave out
write_gyro(0x63, 0x00 );
Delay(10);
write_gyro(0x64, 0x00 );
Delay(10);
write_gyro(0x65, 0x00 );
Delay(10);
write_gyro(0x66, 0x00 );
Delay(10);
//More slave config
write_gyro(0x67, 0x00 );
Delay(10);
//Controls frequency of wakeups in accel low power mode plus the sensor standby modes
write_gyro(0x6C, 0x00 );
Delay(10);
//Data transfer to and from the FIFO buffer
write_gyro(0x74, 0x00 );
Delay(10);
void Calibrate_Gyros()
int ki;
for (ki = 0; ki < 50; ki++)
xh = read_gyro(67);
xl = read_gyro(68);
yh = read_gyro(69);
yl = read_gyro(70);
zh = read_gyro(71);
zl = read_gyro(72);
GYRO_XOUT_OFFSET_1000SUM += ((GYRO_XOUT_H << 8) | GYRO_XOUT_L);
GYRO_YOUT_OFFSET_1000SUM += ((GYRO_YOUT_H << 8) | GYRO_YOUT_L);
GYRO_ZOUT_OFFSET_1000SUM += ((GYRO_ZOUT_H << 8) | GYRO_ZOUT_L);
GYRO_XOUT_OFFSET = (GYRO_XOUT_OFFSET_1000SUM / 50);
GYRO_YOUT_OFFSET = (GYRO_YOUT_OFFSET_1000SUM / 50);
GYRO_ZOUT_OFFSET = (GYRO_ZOUT_OFFSET_1000SUM / 50);
void convert_n_send(int ADCValue)
UART0Send_1Byte(((ADCValue / 100) % 10) + '0');
UART0Send_1Byte(((ADCValue / 10) % 10) + '0');
UART0Send_1Byte((ADCValue % 10) + '0');
UART0Send_1Byte(0x0a);
UART0Send_1Byte(0x0d);
// Main Function
// Modified Date: 26 Sep 14
// Modified By: Sheetal
int main(void)
PINSEL0 = 0x00000000;
PINSEL1 = 0x00000000;
PINSEL2 = 0x00000000;
// IODIR0 = 0xFFFFFFFF;
// IODIR1 = 0xFFFFFFFF;
Init_Timer( 0 );
Enable_Timer( 0 );
UART0Init( 9600 );
// UART0Send("Amit", 4);
configure_gyro();
// Calibrate_Gyros();
// while(1)
// UART0Send("A", 1);
// Delay(1000);
UART0Send("S", 1);
while(1)
// st = read_gyro(0x61);
xh = read_gyro(67);
Delay(10);
UART0Send("1", 1);
Delay(10);
xl = read_gyro(68);
Delay(10);
UART0Send("2", 1);
Delay(10);
yh = read_gyro(69);
Delay(10);
UART0Send("3", 1);
Delay(10);
yl = read_gyro(70);
UART0Send("4", 1);
Delay(10);
zh = read_gyro(71);
Delay(10);
UART0Send("5", 1);
Delay(10);
zl = read_gyro(72);
UART0Send("6", 1);
Delay(10);
UART0Send("A", 1);
UART0Send_1Byte(xh);
UART0Send_1Byte(xl);
UART0Send_1Byte(yh);
UART0Send_1Byte(yl);
UART0Send_1Byte(zh);
UART0Send_1Byte(zl);
UART0Send("C", 1);
Delay(1000);
