fethiyeli
Full Member level 4
I am planning to design smps that has variable output voltage and current. Its voltage will change 0-50V and current will change 0-10A.
Vout comes from output voltage up to 50V. Iout comes from output current up to 10A. Iout will be Rshunt x 10A. Rshunt is 0.05R, so Iout will be 0.5V as voltage. Output pin of 1 and 8 changes between 0 and 2.5V according to Vout and Iout. But Vfb is not changing linearly between 0-2.5V. I am using UC3844 so its non-inverting input is connected to 2.5V, therefore VFB which is connected to inverting input of UC3844, must be 2.5V at most. My question is how can i change the VFB voltage linearly between 0 and 2.5V when i use the potentiometer. These potentiometers are for voltage and current control. Do you have any suggestion to control of voltage and current of SMPS output ?
