[MOVED] sony dvcam picture problem
ektorcela
Junior Member level 3
I have a sony dvcam 1800,and it shows the picture a little disordered. I have changed SUB ASSY, RAIL and again the same problem. I suspect that is the Drum assembly. If is the drum assembly how can I understand? thank you
You need to provide more info about the related problems.
Changing some mechanical elements impose a tape path re-adjustment. In order to proceed to this operation you need to have the alignment tapes.
See the service manual for additional details.
  • sony_dsr-1800_vol1.pdf
  • sony_dsr-1800_vol2.pdf
