I don't think you can program the chip flash using the studio interface, is you programmer supported in studio?
I only know it supports the Atmel programmers.
Before installing AVR Studio WinAVR is also to be installed as far as I understand, worth checking.
If the Code is compiling this does not apply, hence be ignored.
hey my dear friend I have also concern to the programer provider. and it came to that he gave me Progisp instead of avrisp........ so I think due to this my device was connecting with avr studio 4. What is ur openion about it.?
hi my dear friends.
I m trying to program Atmega8l by progisp 1.72 . But here I m facing a problem. When I connect the programer to the laptop ...... The lap detect it and the icon of ProgIsp is highlighted. but when I attached the Atmega 8l to it and give READ Command. The chip enable program Error is comming. I have made all the connection very well according to progISP requriment i.e. [Bold]ISP PIN MCU PIN
1 MOSI
2 VCC
3 XTAL (9)
4,6,8 No Connection
5 RESET (1)
7 SCK
9 MISO
10 Ground
Please can u help me on this topic. I m in the big confusion. One thing I would like to tell you that I have attached this MCU in my circuit but power suply is off. Till then the error is comming. [/Bold]
hi my dear friends.
1 MOSI (17)
2 VCC(7)
3 XTAL (9)
4,6,8 No Connection
5 RESET (1)
7 SCK (19)
9 MISO (18)
10 Ground(8,22)
hi my dear friends.
I m trying to program Atmega8l by progisp 1.72 . But here I m facing a problem. When I connect the programer to the laptop ...... The lap detect it and the icon of ProgIsp is highlighted. but when I attached the Atmega 8l to it and give READ Command. The chip enable program Error is comming. I have made all the connection very well according to progISP requriment i.e............... [Bold]ISP PIN.......................MCU PIN
1 .................................. MOSI
2 ................................ VCC
3 ............................. XTAL (9)
4,6,8 .............................No Connection
5 .................................RESET (1)
7 ...................................SCK
9 ................................... MISO
10 ................................. Ground
hi my dear friends.
I m trying to program Atmega8l by progisp 1.72 . But here I m facing a problem. When I connect the programer to the laptop ...... The lap detect it and the icon of ProgIsp is highlighted. but when I attached the Atmega 8l to it and give READ Command. The chip enable program Error is comming and after that unknown device or usb derive is not successfully installed error come. I have made all the connection very well according to progISP requriment i.e...............
1 .................................. MOSI (17)
2 ................................ VCC (7)
7 ...................................SCK (19)
9 ................................... MISO (18)
10 ................................. Ground (8,22)
PL read last one update. upper updates contains less information.
hi dear friend. I have solve the above program error.
But now here is one problem,................
during the compiling and built the program error is comming, can any one help me how to remove the error.. the error is...
make: *** No rule to make target `amar', needed by `elf'. Stop.
Build failed with 1 errors and 0 warnings...
