kodiak
Greetings, guys! I'm trying to increase the frequency of a Wien's Bridge up to at least 600kHz. As R1=R2 and C1=C2, the frequency should be given by \[\frac{1}{2ΠRC}\], but this relation does not fit the simulated frequency when it goes higher than 14k~15kHz. I'm aware that the Wien's Bridge was not meant to work with frequencies this high, but I just can't understand why it stops working. The following circuit should oscilate in 1.4MHz, but in the simulation it seems to oscilate in 440kHz.
I would think that this would be related to the Opamp I'm using, but I have already made a TL072 oscilate in MHz with a different oscilation circuit. So, would you have any idea of what's going on with the circuit that does not allow it to oscilate faster? What could I do?
Thank you.
Thank you.
