[MOVED] #include <sys/io.h> file not found
shaswat
Full Member level 1
Hi all,
I am working on writing my device driver code. This time I write code for my DB-25 parallel port, but for this I have to use
sys/io.h
header file. As per my compiler error, its not found in directory. For this, I download the header file and insert in the directory. But still error found.
What now I have to do? Is there any other header file for low level port input output ???
Thanks.....
Re: #include <sys/io.h> file not found
Perhaps u'll get better answers in the "PC Programming and Interfacing" or "Embedded Systems and Real-Time OS
" forums.
Do you understand to which directory #include <sys/xxx> refers? It's the compiler's include/sys directory, not the application dir. Apparently your compiler isn't a regular PC or embedded compiler, otherwise io.sys would be already in place. You can of course change the #include statement to any place where io.sys can be found, e.g. "io.sys" for the application dir. But makes the content of io.sys sense for this compiler?
Hello,
please post the command you are compiling with, e.g. gcc -foo -bar.
Arnobert
Re: [MOVED] #include &lt;sys/io.h&gt; file not found
Hello,
Arnobert
I am using "make" command to compile my code.
Please can you elaborate or put some light on your comment
it's the compiler's include/sys directory, not the application dir.
. And of course I use "io/sys.h" in my running directory. But that also not helps.
I meaned you need to understand what's the difference between
#include <sys/io.h>
and
#include "io.h"
And should use the correct #include syntax for actual file location.
#include <sys/io.h>
and
#include "io.h"
I also tried with
#include "io.h"
but that header file include another header file names
features.h
. This time again I download it, saved in my current working directory. Now, I have an error with message
#include <sys/cdefs.h>
No such file or directory
io.h has the definition of low-level runtime functions, some compilers have it in the general include directory <io.h>, some have it under <sys/io.h>. It's ususally referencing other include files. Copying io.h from a different compiler doesn't necessarily work, instead you should find out how the respective functions are provided by your compiler, if it has io.h and where it is located. It may be necessary to modify also the code itself, write wrapper functions or at least some #defines.
This are necesary steps when porting C code between different computer platforms or compilers.
