[MOVED] how to remove this error in xilinx
krishna2728
Member level 5
bengaluru,India
ERROR:HDLCompilers:110 - "C:/Xilinx92i/NFC/piccA_noF1.v" line 81 Least significant bit operand in part-select of vector reg 'temp1' is illegal
i have to compare a array temp1[7:-temp]== uid[39:-temp];
my temp value keeps on changing and i have written as above i am getting the error as above how to write this with out any error plz helpme
Thank u in advance
Re: how to remove this error in xilinx
As far as i know,in verilog the range values must be a constant
also i think u must post this in fpga group, to get better response..
Can you post the part of ur code here so that we can correct it and show you how to do it right?
"memcoll [1]<=rxmemory [1]- 8'h20;
temp<=memcoll [1];
temp1[7:-temp]== uid[39:-temp];"
this is my code plz help
temp<=memcoll [1];
What I understand from ur code is temp and temp1 are 8 bit variables
and this is what you want to do!
case (temp)
0 : equal = temp1[7]== uid[39];
1 : equal = temp1[7:6]== uid[39:38];
3 : equal = temp1[7:5]== uid[39:37];
4 : equal = temp1[7:4]== uid[39:36];
5 : equal = temp1[7:3]== uid[39:35];
6 : equal = temp1[7:2]== uid[39:34];
7 : equal = temp1[7:1]== uid[39:33];
default : equal = temp1[7:0]== uid[39:32];
endcase
