Van-Long Tran
Newbie level 2
I designed of a high voltage power supply to charge a capacitor bank by constant current with the phase shift full bridge converter. In the circuit, I can only measure the peak value of the inductor current by using a CT and estimate the average current. The circuit worked well with the resistor load, but it has a serious problem with the power capacitor bank. The controller did not work properly, the charge current varied with a large scale leading to the broken phenomenon of the Mosfets. How can I solve that problem?
P/S: The average value of the inductor current can not be sensed directly from the circuit. It was estimate from the peak current value. There is a necessity to get the average value directly, but I still do not know how to do it in a simple way.
