There are capacitor manufacturers, they provide all informations you need. They provide datasheets, online selection tools, formulas, ...I'm finding the capacitor that have low capacitive and high RMS current, so where I can buy it?
Please recommend the site or company or something..
110nF ~ 220nF, over 600V, 30Arms, 100kHzCapacitance, voltage, current, frequency?
You can check out Mouser, Digi-Key, or RS Components. They have a wide range of capacitors with detailed specs. If you need something specific, KEMET and Vishay also make low-capacitance, high-RMS current caps.I'm finding the capacitor that have low capacitive and high RMS current, so where I can buy it?
I need total capacitance 110nF~220nF. I can use parallel capacitors if the current capacity lacks.What value do you need? I mean how many farads/pico farads or microfarads are you looking for?
I couldn't a capacitor in Mouser, digikey. I'll find in RS component. ThanksYou can check out Mouser, Digi-Key, or RS Components. They have a wide range of capacitors with detailed specs. If you need something specific, KEMET and Vishay also make low-capacitance, high-RMS current caps.
What´s this 600V?110nF ~ 220nF, over 600V, 30Arms, 100kHz
600Vdc, but, I think 2kV because of the current capacity.What´s this 600V?
--> V_RMS, V_p, V_pp, something else?
Waveform:
--> sine?
Klaus
This makes no sense.600Vdc, but, I think 2kV because of the current capacity.
Oh.. I'm so sorry.... My explanation was so lacking..Hi,
600V DC... DC means no frequency, but before you talked about 100 kHz.
What is now this "2kV" statement? What has it to do with current capacity?
--> draw a sketch how you expect the voltage at the capacitor to look like
Klaus
I really thanks about your advice. I will look up a capacitor in the pdf and general atomics.I used grok to help locate the best supplier of components in your category. The first source was General Atomics in the component division for electromagnetics. They offer solutions up to 1 MA in the C, V and f range of your requirements.
