MOSFET alternatives for 2n3904 and 2n3906?
Euler's Identity
2n3904 vs mosfet
When doing any manner of low voltage switching in the past, I've relied on either the 2n3904 or the 2n3906, both 250mA-max devices. However, I'd like to find similar "ye ole trusty" MOSFETs to add to my toolbox, so I figured I'd ask about it here. I'm lookng for enhancement-type, as I want the devices to be normally off.
The 2n3904 and 2n3906 are very common complementary devices, readily available. Likewise, I have SPICE models for each, but with regards to similar MOSFETs, I have zip.
What would you recommend as MOSFET substitutes for the 2n3904 and the 2n3906?
...also, with an NPN or PNP, you can't make a voltage controlled resistor, at least not a linear one nor one that swings above and below ground. That's all about an FET, a MOSFET.
2n3906 alternatives
I didn't realize my question would be so difficult. :-(
I went with
ZVP2106A-ND MOSFET P-CH 60V 280MA TO-92
ZVN3306A-ND MOSFET N-CH 60V 270MA TO-92
Vgs = 1.5 -> 3.5 (n-ch) / 0.8 -> 2.4 (p-ch)
Rds(on) = 5Ω
These seemed reasonable. Plus I have SPICE models for these, so I can minimize my surprises.
Added after 3 minutes:
Actually, I goofed on my 2n3904 and 3906 currents. It should've been 200mA, so my MOSFETs aren't quite the same, but they're close enough.
