tryingsth
Junior Member level 2
![Junior Member level 2](/styles/images/ranks/clevel2.gif)
- Joined
- Nov 21, 2012
- Messages
- 23
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,458
more thn one UseClause imports declaration of simple name "unsigned" none of the dec
hello again,
I need your helps.I couldn't find solution of this error: Error (10621): VHDL Use Clause error at Projem_With_adder.vhd(39): more than one Use Clause imports a declaration of simple name "unsigned" -- none of the declarations are directly visible
I search on the internet but i couldn't find.I attach my code.
the error at this line:
function adder (A,B : in integer) return unsigned is
hello again,
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; USE work.my_data_types.all; use ieee.std_logic_arith; use ieee.numeric_std.all; ENTITY Projem_With_adder IS GENERIC (n : INTEGER := 4); PORT( clk : IN STD_LOGIC; --matris_in : IN integer_array(0 TO n+1); matris_out : OUT int_arr_out; we : in std_logic ); end Projem_With_adder; architecture behv of Projem_With_adder is SIGNAL matris_in :integer_array :=((0,0,0,0,0,0), (0,25,69,54,30,0), (0,215,14,3,98,0), (0,51,150,117,200,0), (0,100,13,82,9,0), (0,0,0,0,0,0)); SIGNAL s1,s2,s3,s4,s5,s6,s7,summary : std_logic_vector(7 downto 0); VARIABLE counter : INTEGER; TYPE state IS (st0,st1,st2,st3,st4); SIGNAL pr_state,nx_state: state; function adder (A,B : in integer) return unsigned is variable tmp: unsigned(8 downto 0); variable SUM: unsigned(7 downto 0); begin --tmp := (conv_unsigned(A,8) + conv_unsigned(B,8) ); -- G1 : FOR i IN 0 TO 7 LOOP -- if (A(i) XOR ( B(i) XOR CI )) =1 then --tmp(i) := '1'; --else tmp(i) := 0; --end if; --end LOOP; --SUM:=tmp (7 downto 0); --co:=tmp(8); return SUM; end adder; BEGIN PROCESS(clk,we) BEGIN if(we='1') then pr_state <=st0; elsif(clk'event and clk = '1') then pr_state <= nx_state; end if; END PROCESS; PROCESS(pr_state,counter) BEGIN counter := 0; FOR i IN 1 TO n LOOP FOR j IN 1 TO n LOOP CASE pr_state IS WHEN st0 => IF(counter = 0) THEN s1<=conv_integer(adder(matris_in(i-1,j-1),matris_in(i-1,j))); s2<=adder(matris_in(i-1,j+1),matris_in(i,j-1)); s3<=adder(matris_in(i,j),matris_in(i,j+1)); s4<=adder(matris_in(i+1,j-1),matris_in(i+1,j)); counter:=counter + 1; nx_state <= st1; end if; WHEN st1 => IF(counter = 1) then s5<=adder(s1,s2); s6<=adder(s3,s4); counter:=counter + 1; nx_state <= st2; end if; WHEN st2 => IF(counter = 2) THEN s7<=adder(s5,s6); counter:=counter + 1; nx_state <= st3; end if; WHEN st3 => IF(counter = 3) THEN summary<=(s7,matris_in(i+1,j+1)); matris_out(i,j)<=conv_integer(summary); end if; END CASE; end loop; end loop; end process; end behv;
