Monopole antenna simulation
100drine
Newbie level 1
monopole antenna
Hi everyone,
I am completely new at HFSS (v10) and I need to model a vertical monopole antenna. I want it to work at 434 MHz and therefore made it 17 cm long (in stainless steel). I also added a infinite ground plane (in perfect conductor), a wave port and an air box.
The radiation pattern looks alright but somehow the antenna doesn't resonate at all at 434 MHz. Can anyone tell me why ? And how to make it work properly ?
Thank you very much.
100drine
e_m_c
Full Member level 3
Land
inurl:viewtopic simulation
It would be more useful if you attach your model.
asturias
Member level 3
antenna simulation
You could check the length of your monopole so as to be lamda/4. try to optimise it by increasing/decreasing that length a little bit till you reach the resonant point. Have a look at the radius of your wire(if it is a wire antenna).
An important thing as well is your feeding strure, are you sure that it is 50 Ohms?
It should work somehow. If you need additional help let me know
