Monolithic Flyback switchers for high voltage DC ouput
sabu31
Advanced Member level 1
Hi all,
I would like to know if there are monolithic switcher ICs for flyback topology to achieve +5kV DC (5 Watts) from standard single phase AC 230V rms. Most of the sites i checked, give upto 1000 V design (LT 8304) . Thanks .
correct me if I´m wrong...
But doesn´t the output voltage of a flyback depend on winding count (ratio) of the used transformer.
--> The switcher IC will never see the high output voltage.
The switcher IC will just see the DC input voltage (plus spikes)
I can´t see that LT8304 can be used for 230V AC input
nor can I see any 1000V ouput voltage specification.
Please clarify.
Klaus
Reactions: sabu31
    sabu31
If you can divide down the o/p volts and have enough power to run an opto or other feedback loop - then you can run most any off the shelf flyback controller ...
kind regards, EP.
Reactions: sabu31
    sabu31
kind regards, EP.
Is it possible to use the switcher ICs or general purpose PWM controllers in Open loop.
"Flyback" and "open loop" is not a good idea.
With low (no) load the output voltage will go unwantedly high ... maybe until a device breaks down in overvoltage.
I recommend to read through some SMPS basics for different topologies.
Klaus
open loop means you have no control of Vout, so if you design for a given load and that load is removed the volts will go up to unknown levels - similarly - if you put desired load on you have no idea what actual Vout is ...
