Fritzik
Newbie level 2
hello
this is a module that should generate a BF_Switch by code (preperation for more then one)
i've tested the BF_Switch module and it works fine, but when i generated all of the wires and the module something got mixed up or something
here is the code:
for some reason i dont get any outputs OR - more strangly - only"Out_r" goes through and the others dont (i get zeros in simulation).
any thoughts or suggestions ?
plz help.
edit: still waiting - i realy need this help
here is the code:
module BF_Network(In_l,In_r,S_In_l,S_in_r,Clock,Out_l,Out_r,S_Out_l,S_Out_r);
parameter SIZE = 2; // k == SIZE
parameter ROWNUM = 0; // for i
parameter HEIGHT = 0; // for j
input [SIZE-1:0] In_l,In_r;
input S_In_l,S_in_r,Clock;
output [SIZE-1:0] Out_l,Out_r;
output S_Out_l,S_Out_r;
reg [SIZE-1:0] Out_l,Out_r;
wire [SIZE-1:0] TEMP_Out_l,TEMP_Out_r;
wire [1:0]IW_IOL[1:0];
wire [1:0]IW_IOR[1:0];
wire IW_SIOL[1:0];
wire IW_SIOR[1:0];
assign IW_IOL[0] = In_l;
assign IW_IOR[0] = In_r;
assign IW_SIOL[0] = `One;
assign IW_SIOR[0] = `One;
genvar j ;
generate for (j=0; j<1; j=j+1)
begin:Build_Net
//generate module BF_Network(In_l,In_r,S_In_l,S_in_r,Clock,Out_l,Out_r,S_Out_l,S_Out_r);
BF_Switch #(SIZE,j) sw(IW_IOL[j],IW_IOR[j],IW_SIOL[j],IW_SIOR[j],Clock,IW_IOL[j+1],IW_IOR[j+1],IW_SIOL[j+1],IW_SIOR[j+1]);
end
endgenerate
assign TEMP_Out_l = IW_IOL[1];
assign TEMP_Out_r = IW_IOR[1];
assign S_Out_l = IW_SIOL[1];
assign S_Out_r = IW_SIOR[1];
always @ (TEMP_Out_l or TEMP_Out_r) begin
Out_l <= TEMP_Out_l;
Out_r <= TEMP_Out_r;
end
endmodule
plz help.
