oAwad
Full Member level 2
The exported map file from Encounter is wrong, so how to modify it to be able to get the correct layers in Virtuoso ?
Here is streamOut.map file from Encounter:
and here is the library technology file (it contains the correct layer numbers):
Thanks
metal1 NET 1 0
metal1 SPNET 2 0
metal1 PIN 3 0
metal1 LEFPIN 4 0
metal1 FILL 5 0
metal1 FILLOPC 6 0
metal1 VIA 7 0
metal1 VIAFILL 8 0
metal1 VIAFILLOPC 9 0
metal1 LEFOBS 10 0
NAME metal1/NET 11 0
NAME metal1/SPNET 12 0
NAME metal1/PIN 13 0
NAME metal1/LEFPIN 14 0
via1 LEFPIN 15 0
via1 FILL 16 0
via1 FILLOPC 17 0
via1 VIA 18 0
via1 VIAFILL 19 0
via1 VIAFILLOPC 20 0
metal2 NET 21 0
metal2 SPNET 22 0
metal2 PIN 23 0
metal2 LEFPIN 24 0
metal2 FILL 25 0
metal2 FILLOPC 26 0
metal2 VIA 27 0
metal2 VIAFILL 28 0
metal2 VIAFILLOPC 29 0
metal2 LEFOBS 30 0
NAME metal2/NET 31 0
NAME metal2/SPNET 32 0
NAME metal2/PIN 33 0
NAME metal2/LEFPIN 34 0
via2 LEFPIN 35 0
via2 FILL 36 0
via2 FILLOPC 37 0
via2 VIA 38 0
via2 VIAFILL 39 0
via2 VIAFILLOPC 40 0
metal3 NET 41 0
metal3 SPNET 42 0
metal3 PIN 43 0
metal3 LEFPIN 44 0
metal3 FILL 45 0
metal3 FILLOPC 46 0
metal3 VIA 47 0
metal3 VIAFILL 48 0
metal3 VIAFILLOPC 49 0
metal3 LEFOBS 50 0
NAME metal3/NET 51 0
NAME metal3/SPNET 52 0
NAME metal3/PIN 53 0
NAME metal3/LEFPIN 54 0
via3 LEFPIN 55 0
via3 FILL 56 0
via3 FILLOPC 57 0
via3 VIA 58 0
via3 VIAFILL 59 0
via3 VIAFILLOPC 60 0
metal4 NET 61 0
metal4 SPNET 62 0
metal4 PIN 63 0
metal4 LEFPIN 64 0
metal4 FILL 65 0
metal4 FILLOPC 66 0
metal4 VIA 67 0
metal4 VIAFILL 68 0
metal4 VIAFILLOPC 69 0
metal4 LEFOBS 70 0
NAME metal4/NET 71 0
NAME metal4/SPNET 72 0
NAME metal4/PIN 73 0
NAME metal4/LEFPIN 74 0
via4 LEFPIN 75 0
via4 FILL 76 0
via4 FILLOPC 77 0
via4 VIA 78 0
via4 VIAFILL 79 0
via4 VIAFILLOPC 80 0
metal5 NET 81 0
metal5 SPNET 82 0
metal5 PIN 83 0
metal5 LEFPIN 84 0
metal5 FILL 85 0
metal5 FILLOPC 86 0
metal5 VIA 87 0
metal5 VIAFILL 88 0
metal5 VIAFILLOPC 89 0
metal5 LEFOBS 90 0
NAME metal5/NET 91 0
NAME metal5/SPNET 92 0
NAME metal5/PIN 93 0
NAME metal5/LEFPIN 94 0
via5 LEFPIN 95 0
via5 FILL 96 0
via5 FILLOPC 97 0
via5 VIA 98 0
via5 VIAFILL 99 0
via5 VIAFILLOPC 100 0
metal6 NET 101 0
metal6 SPNET 102 0
metal6 PIN 103 0
metal6 LEFPIN 104 0
metal6 FILL 105 0
metal6 FILLOPC 106 0
metal6 VIA 107 0
metal6 VIAFILL 108 0
metal6 VIAFILLOPC 109 0
metal6 LEFOBS 110 0
NAME metal6/NET 111 0
NAME metal6/SPNET 112 0
NAME metal6/PIN 113 0
NAME metal6/LEFPIN 114 0
via6 LEFPIN 115 0
via6 FILL 116 0
via6 FILLOPC 117 0
via6 VIA 118 0
via6 VIAFILL 119 0
via6 VIAFILLOPC 120 0
metal7 NET 121 0
metal7 SPNET 122 0
metal7 PIN 123 0
metal7 LEFPIN 124 0
metal7 FILL 125 0
metal7 FILLOPC 126 0
metal7 VIA 127 0
metal7 VIAFILL 128 0
metal7 VIAFILLOPC 129 0
metal7 LEFOBS 130 0
NAME metal7/NET 131 0
NAME metal7/SPNET 132 0
NAME metal7/PIN 133 0
NAME metal7/LEFPIN 134 0
via7 LEFPIN 135 0
via7 FILL 136 0
via7 FILLOPC 137 0
via7 VIA 138 0
via7 VIAFILL 139 0
via7 VIAFILLOPC 140 0
metal8 NET 141 0
metal8 SPNET 142 0
metal8 PIN 143 0
metal8 LEFPIN 144 0
metal8 FILL 145 0
metal8 FILLOPC 146 0
metal8 VIA 147 0
metal8 VIAFILL 148 0
metal8 VIAFILLOPC 149 0
metal8 LEFOBS 150 0
NAME metal8/NET 151 0
NAME metal8/SPNET 152 0
NAME metal8/PIN 153 0
NAME metal8/LEFPIN 154 0
via8 LEFPIN 155 0
via8 FILL 156 0
via8 FILLOPC 157 0
via8 VIA 158 0
via8 VIAFILL 159 0
via8 VIAFILLOPC 160 0
metal9 NET 161 0
metal9 SPNET 162 0
metal9 PIN 163 0
metal9 LEFPIN 164 0
metal9 FILL 165 0
metal9 FILLOPC 166 0
metal9 VIA 167 0
metal9 VIAFILL 168 0
metal9 VIAFILLOPC 169 0
metal9 LEFOBS 170 0
NAME metal9/NET 171 0
NAME metal9/SPNET 172 0
NAME metal9/PIN 173 0
NAME metal9/LEFPIN 174 0
via9 LEFPIN 175 0
via9 FILL 176 0
via9 FILLOPC 177 0
via9 VIA 178 0
via9 VIAFILL 179 0
via9 VIAFILLOPC 180 0
metal10 NET 181 0
metal10 SPNET 182 0
metal10 PIN 183 0
metal10 LEFPIN 184 0
metal10 FILL 185 0
metal10 FILLOPC 186 0
metal10 VIA 187 0
metal10 VIAFILL 188 0
metal10 VIAFILLOPC 189 0
metal10 LEFOBS 190 0
NAME metal10/NET 191 0
NAME metal10/SPNET 192 0
NAME metal10/PIN 193 0
NAME metal10/LEFPIN 194 0
NAME COMP 195 0
COMP ALL 196 0
DIEAREA ALL 197 0
; Technology File NCSU FreePDK 45nm
; LAYER DEFINITION
layerDefinitions(
techLayers(
;( LayerName Layer# Abbreviation )
( IP 63 IP )
( nwell 3 nwell )
( pwell 2 pwell )
( nimplant 4 nimplant )
( pimplant 5 pimplant )
( active 1 active )
( vtg 6 vtg )
( vth 7 vth )
( thkox 8 thkox )
( poly 9 poly )
( contact 10 contact )
( metal1 11 metal1 )
( via1 12 via1 )
( metal2 13 metal2 )
( via2 14 via2 )
( metal3 15 metal3 )
( via3 16 via3 )
( metal4 17 metal4 )
( via4 18 via4 )
( metal5 19 metal5 )
( via5 20 via5 )
( metal6 21 metal6 )
( via6 22 via6 )
( metal7 23 metal7 )
( via7 24 via7 )
( metal8 25 metal8 )
( via8 26 via8 )
( metal9 27 metal9 )
( via9 28 via9 )
( metal10 29 metal10 )
( DRC 400 DRC )
) ;techLayers
techLayerPurposePriorities(
;layers are ordered from lowest to highest priority
;( LayerName Purpose )
( IP drawing )
( nwell drawing )
( pwell drawing )
( nimplant drawing )
( pimplant drawing )
( active drawing )
( vtg drawing )
( vth drawing )
( thkox drawing )
( poly drawing )
( contact drawing )
( metal1 drawing )
( via1 drawing )
( metal2 drawing )
( via2 drawing )
( metal3 drawing )
( via3 drawing )
( metal4 drawing )
( via4 drawing )
( metal5 drawing )
( via5 drawing )
( metal6 drawing )
( via6 drawing )
( metal7 drawing )
( via7 drawing )
( metal8 drawing )
( via8 drawing )
( metal9 drawing )
( via9 drawing )
( metal10 drawing )
( DRC drawing )
) ;techLayerPurposePriorities
techDisplays(
;( LayerName Purpose Packet Vis Sel Con2ChgLy DrgEnbl Valid )
( IP drawing PacketName_0 t t t t t )
( nwell drawing PacketName_2 t t t t t )
( pwell drawing PacketName_3 t t t t t )
( nimplant drawing PacketName_4 t t t t t )
( pimplant drawing PacketName_5 t t t t t )
( active drawing PacketName_6 t t t t t )
( vtg drawing PacketName_11 t t t t t )
( vth drawing PacketName_12 t t t t t )
( thkox drawing PacketName_13 t t t t t )
( poly drawing PacketName_14 t t t t t )
( contact drawing PacketName_19 t t t t t )
( metal1 drawing PacketName_26 t t t t t )
( via1 drawing PacketName_30 t t t t t )
( metal2 drawing PacketName_31 t t t t t )
( via2 drawing PacketName_35 t t t t t )
( metal3 drawing PacketName_36 t t t t t )
( via3 drawing PacketName_40 t t t t t )
( metal4 drawing PacketName_41 t t t t t )
( via4 drawing PacketName_45 t t t t t )
( metal5 drawing PacketName_46 t t t t t )
( via5 drawing PacketName_50 t t t t t )
( metal6 drawing PacketName_51 t t t t t )
( via6 drawing PacketName_55 t t t t t )
( metal7 drawing PacketName_56 t t t t t )
( via7 drawing PacketName_60 t t t t t )
( metal8 drawing PacketName_61 t t t t t )
( via8 drawing PacketName_65 t t t t t )
( metal9 drawing PacketName_66 t t t t t )
( via9 drawing PacketName_70 t t t t t )
( metal10 drawing PacketName_71 t t t t t )
( DRC drawing PacketName_77 t t t t t )
) ;techDisplays
) ;layerDefinitions
Thanks
