Modelsim:- Waveform does not appear on the wave window
srinpraveen
Member level 2
Hi!
I have a perplexing problem and its very irritating. I tried simulating a simple counter in modelsim pe student edition 10.0a. Yesterday the simulation worked and I was able to see the waves in the modelsim wave window after adding the signals to the wave. But today morning after I rebooted my laptop and tried opening modelsim and repeating the same process, I am not able to see any waveform on the wave window.
Here is a checklist of the procedure I followed.
1) I started modelsim.
2) I added counter.v and counter_tb.v to a project.
3) I clicked "Start simulation" in the "Simulate menu"
4) The I clicked my testbench module name under the work directory.
5) Then I clicked on the "Objects" tab and selected all the signals, right clicked, wave, add to wave all the signals in the design.
6) Now when I move to wave tab and click run icon i don't see any of the green waveforms.
This procedure worked yesterday and is not working today. I have enclosed a screenshot of my wave window. Modelsim was installed only 3 weeks back and I don't think there is anything to do with licensing because I tried uninstalling modelsim, reinstalling and repeating the same process but again that was to no effect.
Here is my counter code.
module mod4_counter(clk, reset, start_count, count_value);
input clk, reset, start_count;
output wire [1:0] count_value;
reg [1:0] pre_count_value;
always @ (posedge clk or posedge reset)
begin
if (reset == 1'b1)
pre_count_value <= 2'b00;
else if (start_count == 1'b1)
pre_count_value <= pre_count_value + 1'b1;
else pre_count_value <= pre_count_value;
end
assign count_value = pre_count_value;
endmodule
Here is my counter testbench.
module testbench1;
reg clk, reset, start_count;
mod4_counter mod4_cnt(clk, reset, start_count, count_value);
initial
begin
clk = 0;
start_count = 1'b0;
#10 reset = 1'b1;
#10 reset = 1'b0;
#10 start_count = 1'b1;
#520 reset = 1'b1;
#50 reset = 1'b0;
end
always
begin
#50 clk = ~clk;
end
endmodule
As you can see in the screenshot, the signals have been added on the wave window and run icon clicked. Yet the waveforms do not turn up. Mind boggling indeed and very stressful as I have some deadlines to meet. PLS help.
Hi the most possible issue could be that the data set is not closed properly.
use dataset close -all
quit -sim
if possible recompile the work folder. (Just right click on work in the libraries tab and select recompile)
Now simulate using vsim only.
Once the vsim is done, add the wave using do wave.do (You can save it from your current wave window itself)
Now give run -all
there are many run buttons and the edit is set to 0ns so maybe you are pressing the button that runs for the period specified in the edit box which is 0.
Try to change it to 100ns or press the run all
Alex
Thanks that was helpful. But earlier I had clicked "run all" and even that didn't work. Now after I reinstalled, invoked modelsim and changed the run length to 1000ns, then the waveforms showed up. First of all, it beats me why the run length got reset suddenly to 0 ns.
But the good thing is I got the waveforms now. Thanks again.
