SphinX
Advanced Member level 3
modelsim do file
Salam,
I'm FPGA Beginner so please can you help me in this problem
From Xilinx WebPack 6.2i i build a schematic (using Xilinx ECS)
The schematic is few logic gates connected together
I named the schematic file "Gates.sch"
And i wrote the next simple DO file "name.txt"
Ok till now
Then from Xilinx ISE, I have lunched the ModelSim 6.0 SE
But ModelSim Give this
There are two errors ? What are these errors mean ?
Then when i ran the do file (name.txt)
It give this
And the wave windows is opened but it was empty.
I have checked the schematic, The name of IO Port 'LowVolt' is OK ?!
Any solution ?
![Oops! :oops: :oops:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Salam,
quit -sim
vsim Gates
view wave
add wave LowVolt
add wave Cord
add wave Temp
add wave Fan
add wave Alarm
force LowVolt 0, 1 10ns -r 20ns
force Cord 0, 1 20ns -r 40ns
force Temp 0, 1 40ns -r 80ns
run 80ns
Ok till now
# do gates.ldo
# ** Warning: (vlib-34) Library already exists at "work".
# Model Technology ModelSim SE vcom 6.0 Compiler 2004.08 Aug 19 2004
# -- Loading package standard
# -- Loading package std_logic_1164
# -- Loading package numeric_std
# ** Error: (vcom-19) Failed to access library 'unisim' at "unisim".
# No such file or directory. (errno = ENOENT)
# ** Error: D:/Modeltech_6.0/win32/vcom failed.
# Error in macro ./gates.ldo line 4# D:/Modeltech_6.0/win32/vcom failed.
# while executing
# "vcom -93 -explicit Gates.vhf"
It give this
ModelSim> do name.txt
# OpenFile "Gates.sch"
# .wave
# ** Error: (vish-4008) Object 'LowVolt' not found.
# Error in macro ./name.txt line 33
# ** Error: (vish-4008) Object 'LowVolt' not found.#
# while executing
# "force LowVolt 0, 1 10ns -r 20ns"
Any solution ?
