set_node_thresh
I am debugging a mixed signal design by using Nanosim + VCS.
The analog circuit is described in spice and the digital circuit is
described in Verilog.
A clock named A2DCLK is generated by analog circuit and feed to digital circuit.
While A2DCLK rise from 0 to 3.3v, the corresponding digital signal is rise from 0 to unknown and then to 1. Because the state of unknown take place, the signals which triggered at the rise edge of A2DCLK in RTL do not change.
always @ (posedge A2DCLK or negedge nRST)
begin
if(~nRST)
f_count[7:0] <=8'h00;
else
f_count[7:0] <= f_count[7:0] + 1;
end
After reset, f_count holding in 0.
Is there a solution?
I have tried the set_node_thresh in Nanosim configure file, but did not work. Then, I added +2state compile direction on VCS complie script, it did not work too.
By the way, does somneone know how to add a sin/cos stimulus in Verilog testbench?
