Mini usb with PIC16F877A
awsikar
Newbie level 6
pic16f877a usb
anyone knows how to interface a mini usb to pic16f877a?
Do I require additional usb ics as such?
I'm quite confuse over the connections to the chip
pic16f877 usb
u mean by "mini usb" a flash memory?
usb pic16f877
Hi guys,
think I didn't post my qns properly.. Here goes:
Anyone knows how to interface a 4-pin mini usb jack connector to pic16f877a?
Do I require additional usb ics like for in the case of serial port using a max232?
I'm quite confuse over the connections to the pic chip..
how to interfacing usb with pic16f877a
USB to serial...
how to interface usb with pic16f877
16f877 cannot be directly connected to a usb if you want to connect it then you need to convert USB to serial using a converter chip such as FT232 from FTDI or you may use a microcontroller with built in usb interface such as 18f2550 and 18f4550.
pic16f877 usb interface
hey guys,
thankz for the prompt reply.. i guess as much the expected answers..
one more qns:
Is it really necessary to have a USB protection IC for the usb port? Can I omit it during my design?
usb in pic16f877
awsikar said:
one more qns:
what do you mean by that? what ic are you refering to? if you are reffering to ft232 ic it is not just a protection ic but a signal/protocol converter too.
pic16f877a usb
i do not have any particular IC in mind.
Maybe talk about USB6B1 (usb protection IC). Is it necesaary to include this for the UBS port?
pic16f877 board usb
Try this link
Pic + USB Host
**broken link removed**.
Fuji
usb on pic16f877
Thankz for the link...
but too bad, I can't read french.. ;)
pic16f877a controller usb
pic16f877a with usb
pic16f877 to usb interface
Then try here instead
usb interfacing with pic16f877a
try this link
