Min. gate length use in spice simulation for 0.18um TSMC MM
Analogworld
Member level 1
Member level 1
tsmc 0.2um process
Hi all,
I was wondering how do I determine the minimum gate length L for the transistor to use in Spice simulation (0.18um or 0.2um)?
I heard that since the lambda=0.1um for 0.18um, so we have to use 0.2um(2*lambda) as the minimum length. However, I also look at the MOSIS website, they said lambda=0.09 for the SCN6M_DEEP model. The site link is the following:
So, could anyone help me to clarify what is minimum gate length that I should/can use when simulating the transistors? Any help would be greatly appreciated.
0.18um spice parameters
Hi
Min gate lenght is nothing but in which Technology ur desiging
for ex: 0.18u ur min gate length is .18u
0.2u technolgy .ur Min gate lenght is .2u
Have a nice time
Added after 3 minutes:
Hi
Have a nice time
0.18um gate length
Thanks for the reply. But it seems the min. gate length that I can use in spice simulation is not only based on the technology process. I have been seen a lot peoples that using 0.2um as the min. length in 0.18um process. I just wondering why is this.
tsmc 0.18u spice.txt
Hi
Generally designers keep their channel length above thier minimum Gate length to avoid channel length modulation ,especially while designing current mirrors...e.t.c
Theoritically/practically u can take 0.18u(basend on ur technology) r whatever as gate length..u should be careful while dimensioning ur length of transistor..as per i said when ur designing Current mirrors...Differential pair..something like that ..
with regards
channel length modulation 0.18 um
If you are designing a standard cell in 0.18u process then ur min length is 0.18u. But as u r using MM process then i guess u r designing an analog or mixed signal block. in that case take the length of ur transistors atleast twice or thrice of ur min length(0.18um).
tsmc 0.18 um length
use minimum for digital
and 4X for current reference
and 2X~3X for analog
