Micro C Code to AVR Studio Compiler
Kryptone
Member level 3
Member level 3
Hello ALL,
Can anyone help me convert my SPWM Micro C Pro for AVR code to be ported to AVR Studio 5 or 6? I want to use a 16Mhz crystal how do I configure the fuse bits for external crystal operation?
I didnt write it but is the code:
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
unsigned int sin_table[32]={0, 100, 199, 296, 390, 480, 566, 645, 718,
783, 840, 889, 928, 958, 979, 989, 989, 979, 958, 928, 889, 840, 783,
 718, 645, 566, 480, 390, 296, 199, 100,0};
#define MOSA PORTD0_bit
#define MOSB PORTD1_bit
#define MOSC PORTD2_bit
#define MOSD PORTD3_bit
unsigned char FlagReg;
#define Direction FlagReg.B0
//0 -> MOS A + D
//1 -> MOS B + C
unsigned int TBL_POINTER_NEW, TBL_POINTER_OLD, TBL_POINTER_SHIFT, SET_FREQ;
unsigned int TBL_temp;
unsigned char DUTY_CYCLE;
void interrupt() org IVT_ADDR_TIMER1_OVF{
     TBL_POINTER_NEW = TBL_POINTER_NEW + SET_FREQ;
         if (TBL_POINTER_NEW < TBL_POINTER_OLD){
           if (Direction == 0){
              MOSA = 0;
              MOSD = 0;
              MOSB = 1;
              MOSC = 1;
              Direction = 1;
           else{
                MOSB = 0;
                MOSC = 0;
                MOSA = 1;
                MOSD = 1;
                Direction = 0;
        TBL_POINTER_SHIFT = TBL_POINTER_NEW >> 11;
        DUTY_CYCLE = TBL_POINTER_SHIFT;
        TBL_POINTER_SHIFT = sin_table[DUTY_CYCLE];
        OCR1AH = TBL_POINTER_SHIFT >> 8;
        OCR1AL = TBL_POINTER_SHIFT & 0x0F;
        TBL_POINTER_OLD = TBL_POINTER_NEW;
void main() {
     SET_FREQ = 410;
     TBL_POINTER_SHIFT = 0;
     TBL_POINTER_NEW = 0;
     TBL_POINTER_OLD = 0;
     DUTY_CYCLE = 0;
     DDRC = 0xFF;
     DDRD = 0XFF;
     OCR1AH = 0;
     OCR1AL = 0;
     TCCR1A = 0x82;
     ICR1H = 0x03;
     ICR1L = 0xE7;
     //ICR1 = 999 -> TOP -> 16kHz
     TIMSK = 0x04;
     TCCR1B = 0x19;
     SREG_I_bit = 1;
     while(1);
try this code in mikroC PRO AVR and if you get any errors then zip and post the complete mikroC project files so that it can be fixed.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
#define MOSA PORTD.F0
#define MOSB PORTD.F1
#define MOSC PORTD.F2
#define MOSD PORTD.F3
//0 -> MOS A + D
//1 -> MOS B + C
void interrupt() {
              MOSA = 0;
              MOSD = 0;
              MOSB = 1;
              MOSC = 1;
              Direction = 1;
           else{
                MOSB = 0;
                MOSC = 0;
                MOSA = 1;
                MOSD = 1;
                Direction = 0;
void main() {
     SET_FREQ = 410;
     DUTY_CYCLE = 0;
     DDRC = 0xFF;
     DDRD = 0XFF;
     OCR1AH = 0;
     OCR1AL = 0;
     TCCR1A = 0x82;
     ICR1H = 0x03;
     ICR1L = 0xE7;
     TIMSK = 0x04;
     TCCR1B = 0x19;
     SREG_I_bit = 1;
     while(1);
He wants to covert the microC code to a code that compiles in AVR studio, so I'm not sure how your reply helps in that.
