Sandor Akarki
Newbie level 3
I have a 2" diameter plastic pipe into which objects fall (the pipe stands, 90 degrees to the ground level). Those objects are different shape and density so their speed gaining is not consistent. They do not spin. I would like predict their speed when they end the pipe (fall to the ground). I pretty much can do the software and controller part - I would like to know how it would be the best to measure the speed of the object knowing G. I would like to have 3-4 points where I would collect position information from.
My question is what I should be using here; some sort of RF or IR or similar (to know when the object entered the line) or so?
If you have a particular P/N for the sensor in need, I do appreciate that, too.
