Terminator3
Advanced Member level 3
- Joined
- Feb 25, 2012
- Messages
- 802
- Helped
- 71
- Reputation
- 142
- Reaction score
- 63
- Trophy points
- 1,308
- Activity points
- 9,027
Setup:
1) PCB board with two parallel microstrip lines connected to power divider from one side and to two identical diode mixers from other side. One of lines have a gap for common source FET placement. Before placement gap is soldered with copper foil piece for calibration purposes.
2) Frequency generator for frequency F goes to power divider. One of the outputs of power divider modulated with frequency of ~1kHz making equal to Fm=F+1kHz. Unmodulated frequency acted as LO for two mixers. Modulated frequency used as input for parallel microstrip lines board.
Signal from generator F goes through power divider and modulated with frequency 1kHz. Modulated signal Fm goes to PCB board with parallel microstrip lines. As microstrip lines have identical lengths, relative phase shift must be equal to zero 0. IF would be 1kHz with equal phase for both mixers.
Then we open gap soldered with copper foil and replace it with FET transistor. Now parallel lines have non-zero phase shift because FET provides additional S21 angle phase shift. IF would be still 1kHz for both mixers, but with phase difference equal to S21 angle of a transistor.
Is it feasible to produce at X,Ku bands? Any flaws in this design?
