artem
Referring to your original question about wireless measurement - you can put zero bias diodes connected as bridge . These diodes capasitance is fraction of picof and that is nothing compared to RFID capacitor value . But you will get measurement errors for voltage range closed to diode forward voltage . From test instructions you could see that Hmin Hmax required voltage to be induced on coil about 3V and can add estimated diode forward voltage to get final result, which of coruse does not tend to be as accurate as you will measure it with right equipment.
Test standard to use is selected based on by chip used in tag.
