brucelee2
Member level 2
Hi All,
Im working on project for my final bachelor thesis that involves an EV test bench setup.
DC battery bank(180V)>>Motor-controller>>3-phase delta connected motor.
I need to measure the power at different stages. Does anyone have an idea for measuring the power coming out of the controller/inverter? The problem is the signal patterns leaving the controller, discrete voltage switching. The test setup will be used with labview and data acquired with NI field points.
I know there are 3-Phase power measuring devices out there but not sure how they will behave when exposed to the signal coming out of the inverter/controller.
Ive attached an image of a scope when probing across 2 phases. Any ideas how to measure the power at this stage?
THanks for the help!;-)
Bruce
Bruce
