MCU-free frequency counter, which one to build?
neazoi
Advanced Member level 6
Greece
www.microwave.gr
Hello, I would like to build an mcu-free frequency counter 50MHz max with 1Hz resolution and 8 comon cathode seven segment displays. The simplest I have found is this one **broken link removed**
Have you seen any simpler one?
Also, is there an MCU-based project with the above specs that uses a max of 28-pin DIP MCU?
See some project :
  • !!! 3.5GHz LCD Frequency Counter PIC16F84.rar
  • !!! 10MHz Frequency Counter PIC16F628.rar
  • !!! 50MHz Frequency Counter PIC16F628.rar
  • !!! 60MHz Frequency Meter PIC16F84.rar
See some project :
Thanks, but I told you, I would like to use common cathode 7-segment displays and NOT an lcd
The only MCU-based project I have found is this one http://www.best-microcontroller-projects.com/frequency-counter-circuit.html but he uses a huge MCU and most of the pins are unused, what is the point of doing so?
