mcp1703 voltage regulator
devil6600
Full Member level 5
Full Member level 5
hi
can any one tell me how to calculate capacitance for mcp1703 voltage regulator?
i have tried reading datasheet (page 13-14) but unable to understand how its calculated. i need output to be 3V from a 6v battery.
thanks
  • 22049a.pdf
Data sheet says
• Stable with 1.0 μF to 22 μF output capacitance
If you use battery as source there is no ripple voltage.
Input C = 4.7µF
Output C = 4.7µF
if load current >100mA use output C 10µF
if load current < 20mA use 1...2.2µF
if load is higher frequency circuit f > 100kHz, connect 100nF capacitor ( f > 1MHz 10nF )
parallel to output capacitor.
thanks kak111
can you please tell me how do you calculated 4.7uF
Here is some calculation models
but they are for rectified power source.
In your case source is battery ie no ripple.
Power Supply Design
Power Supply Integrity
Most important function in this circuit is that capacitors make the power source
circuit act like short circuit for all ac-currents supplied to load circuit.
( from f = 0.......needed fmax. )
If load circuit see power source as Z= 0 ohms, in all load situations
output voltage gonna be stable.
