[SOLVED] MBIST is an architecture to design memory,My paper says SRAM is designed,
affreen
Newbie level 3
Newbie level 3
Paper is to be coded in digital,so when SRAM is tested using MBIST,SRAM has to be designed in verilog.So if its possible to design SRAM in verilog,then how is it so..
I want to told you thing is that....mbist is not the architecture to design memory....its the architecture for testing the memory which one is already designed....
