[SOLVED] maximum frequency in pic 16 & 18
Mohamed Slama
Member level 4
Member level 4
hi all
i want to know the maximum frequency at pin T0CK1 in 16f877a & 18f452 to know if i used these pics as a frequency counter will count to what Hertz ?
i try the datasheet but i cant extract these information ...
Re: maximum frequency in pic 16 & 18
See section 5.2 of PIC16F877A datasheet, its named Using Timer0 with an External Clock.
Also see Table 17-6 of PIC16F877A datasheet, it is named Timer0 and Timer1 External Clock Requeriments, parameters 40, 41 & 42. Here the period is in nanoseconds, convert it to Hertz. For 18F... do the same check.
