max tran rule criteria
tachyons
Newbie level 5
Hi All,
On what basis max tran rule is defined? Is it same for all the nets? How is it different and why ? Should we fix all tran violations in the design?
Regards
Tachyons
there is no specific criterion unless you made by yourself, but one thing that all the designer should follow is to make sure the transition time in your design is within the transition time range in library.
