MatLab experienced w/GreenFunction(patch/microstrip antenna)
edinburgh
Member level 3
Member level 3
City of Angels
matlab bessel function patch antenna
Dear Friends,
Could you help me to get a matlab program to calculate a Green function for circular microstrip antenna??/
Anyone has experienced with Matlab for Green function????
Anyone has experineced with Matlab for simulation in circular/ring/dics microstrip/patch antenna???
Need the source code/ to work with this kind of function/ antenna..
Thanks in advance...
Best regards,
EDIN
[/code]
andy2000a
Advanced Member level 2
I hope someone can show MATLAB on cicuit design
eboard ebook have matlab book
circuit analysis use Matlab ,
but only for DC/AC , BJT , Operation Amp analysis , I need
A/D D/A convert INL/DNL gain_error .. or DeltaSigma modulator
or PLL matlab code
g86
Full Member level 4
Full Member level 4
On top of antenna :))
Re: MatLab experienced w/GreenFunction(patch/microstrip ante
I could not see your attached file.. something gone wrong.
:!: :idea: :?:
edinburgh said:
Dear Friends,
Best regards,
EDIN
[/code]
eirp
Advanced Member level 1
Phase center
Hi!
I recommend you to look into
Garg,Bhartia,Bahl,Ittipiboon:MS antenna design handbook.
(uploaded by Basskiler too)
On pp. 144-148 are Greens functions you required.
Next you need equations on pp. 93+
It's quite easy to code, I think it's enough for you..
Time ago I've coded similar program - I have problems with determinig radiation Q, results strongly depends on it...
Regards,
Eirp
edinburgh
Member level 3
Member level 3
City of Angels
Dear eirp & friends,
Thanks a lot for your kindly suggestion & guide...
But I am so poor in Matlab programming....
I've already tried it but it doesn't work...
Actually, I'ld like to find out a matlab program to calculate input impedance of circular sector microstrip antenna..
I've read the pages you mentioned above....I'll try to follow that equation...
Thanks in advance......
Best regards,EDIN
eirp
Phase center
I recommend you to improve in Matlab programming, it's so powerful!!
And necessity in developing all...
If you want, PM me your code..
If you have Greens functions written down in close form, maybe you can try it easier(but much slower) in MathCad.
Good Luck
Eirp
rntsay
Member level 4
Member level 4
here are some m*athematica files that are
related to your question (green functions, ...).
the copyright inside says they came form :
there might be more stiff there too.
Not what you asked for (m*atlab), but maybe helps.
rn
g86
Full Member level 4
Full Member level 4
Here is a code for rectangular patch to obtain the Z para of a single port. To change it into circular follow erip's direction. Be careful during finding the root's of derivative of bessel function. The values given in that book are wrong.
function y=green(a,b,d,er,del,x1,y1,width,fr,L)
c=3*10^8; %velocity of light in m per sec.
eo=8.854*10^(-12); % farad per meter
mu=4*pi*10^(-7); % perm. of substrate.
sum11=0;
w=2*pi*fr;
ksqr=(w^2)*(mu*eo*er*(1-j*del));
for m=0:L
kx=m*pi/a;
if(m==0)
sigma_m=1;
else
sigma_m=2;
end
for n=0:L
ky=n*pi/b;
if(n==0)
sigma_n=1;
else
sigma_n=2;
end
phi_mn_1=(cos(kx*x1))*(cos(ky*y1))*sinc(ky*width/2);
den=((kx^2)+(ky^2)-(ksqr));
su11=sigma_m*sigma_n*phi_mn_1*phi_mn_1;
sum11=sum11+su11/den;
end
end
y=(j*w*mu*d*sum11/(a*b));
eirp said:
Hi!
Regards,
Eirp
lifemaker
Newbie level 1
Newbie level 1
1st i want to send my greating for all and ia hope to help me
in problem with matlab in design of rectangular micro strip antenna
in part to determine distance Z fom edge
Yo=2*G/(((cos(B*Z)).^2)+ (((G.^2+b.^2)/Yo.^2).*(sin(B*Z)).^2-(b/Yo).*sin(2*B*Z)))
i have all variable also Yo how i can get Z from this equation >>>>
