HS
Junior Member level 1
- Joined
- Jul 26, 2006
- Messages
- 19
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- USA / Arizona
- Activity points
- 1,468
Matching two ports on CPW (Coplanar Waveguide) printed circuit board
Hello,
There is a nightmare called CPW pcb design.
I have an FR4 board (1mm thickness) and I need to match two ports.
One port is 50 ohms and the other (antenna) is 23+j38 on 2.4GHz ISM band.
Of course I need to introduce some attenuation on harmonics too: 4.8GHz and 7.3GHz.
Apparently simple for someone using Ansoft Designer and optimizer, but this is a CPW pcb and
I am using two small semirigid coaxial cables to measure this board build with 0402 components.
Help me !
How to calibrate the entire setup ?
Option 1: I have an E5070B VNA which has the option of port extension and of course electronic calibration box too.
But using this option is not straight forward as it was using it on two layers pcb boards with ground plane.
Placing an inductor or a capacitor doesn't perform on the Smith Chart as expected.
Option 2: I did the calibration manually at the end of the semirigids using open, short and a 50ohms resistor to gnd as a load.
Still, the same behaviour. Unrealistic insertion loss, strange behaviour on added components.
Please tell me how to wake up and get smart on tuning this CPW pcb.
Any link on Internet or an application note somwhere which tells the steps to follow ?
Thank you in advance !
HS
Hello,
Help me !
HS
