matching infra red led emitter with detector according to the wavelength?
omid_juve
Full Member level 1
can I use a 940nm infrared led detector with the 850nm and 880nm emitter infrared led ?
If you have the detector part number, look into the datasheet and compare the spectral response at the shorter wavelengths. That way you can estimate your sensitivity loss.
