- Joined
- Jul 4, 2009
- Messages
- 16,264
- Helped
- 5,140
- Reputation
- 10,309
- Reaction score
- 5,127
- Trophy points
- 1,393
- Location
- Aberdyfi, West Wales, UK
- Activity points
- 137,646
No offence meant!
Usually when we use matrix board, the components are on one side and the solder on the other, the component legs passing through the holes.
When you say "not connected" do you mean there is nothing at all connected to the pins?
The voltage on pin 8 (V+) is good
The voltage on pin 4 (V-) is good
The voltage on pin 3 (-in) is good, it should be half of V+ because you are tapping the voltage from two identical resistors.
However, if you do not provide feedback from the output to to inverting input (-in) it will not be able to stabilize it's operating point so the output voltage could drift anywhere between V+ and V-. It sounds like this is what is happening so check the feedback resistor is good (R3 in post #71).
Brian.
Brian.
