MAP error: IDELAYCTRL not founf
syedshan
Advanced Member level 1
Jeonju, South Korea
Dear all,
I am having the following error while doing Mapping phase of the design...But I can't understand why previously I did not get this error
ERROR:physDesignRules:2216 - IDELAYCTRL not found for clock region CLOCKREGION_X0Y2. The IODELAYE1 block
fmc10x_io_buf_adc_inst/fmc10x_io_buf_data_ab/chb_lvds_bufs.data_b[3].iodelay_inst has an IDELAY_TYPE attribute of
FIXED, VARIABLE, or VAR_LOADABLE. This programming requires that there be an IDELAYCTRL block programmed within the
same clock region.
Now I understand that I have to insert IDELAYCTRL somewhere, but previously I never added this in the reference design that I am using.
and that design worked fine since it was provided by the company who provided the board and reference designs...
Now that I change only my code for storing and retreiving data and so on without changing the parts which are responsible for communication with
ADC, i.e. I did not changed IBUFDS and IODELAYE1 etc. things since I have only bookish idea of these things...
Then why am I getting these errors...
Also how to deal with these errors now that I am having it (of course I am looking for material but any expert solution would be helpful)
By the way the code snippet is as below...
-- Use LVDS buffers in HPC and LPC mode when LVDS is selected
cha_lvds_bufs: if (CMOS_N_LVDS = '0') generate
  data_a: for i in 0 to RESOLUTION/2-1 generate
    -- Differantial input buffer
    ibufds_inst : ibufds
    generic map (
      IOSTANDARD => "LVDS_25",
      DIFF_TERM  => TRUE
    port map (
      i  => cha_p(i),
      ib => cha_n(i),
      o  => cha_ddr(i)
    -- Input delay
    iodelay_inst : iodelaye1
    generic map (
      IDELAY_TYPE  => "VARIABLE",--"FIXED",
      IDELAY_VALUE => CHA_IDELAY,
      DELAY_SRC    => "I"
    port map (
      DATAOUT => cha_ddr_dly(i),
      IDATAIN => cha_ddr(i),
      c => clk,
      ce => ce_a,
      inc => inc_a,
      datain => '0',
      odatain => '0',
      clkin => '0',
      rst => rst,
      cntvaluein => conv_std_logic_vector(CHA_IDELAY, 5),
      cinvctrl => '0',
      t => '1'
    -- DDR to SDR
    iddr_inst : iddr
    generic map (
      DDR_CLK_EDGE => "SAME_EDGE_PIPELINED"
    port map (
      q1 => cha_sdr(2*i),
      q2 => cha_sdr(2*i+1),
      c  => clk_ab,
      ce => '1',
      d  => cha_ddr_dly(i),
      r  => '0',
      s  => '0'
  end generate;
end generate cha_lvds_bufs;
Waiting for replies.
Bests,
Shan
