Making your ICD2 With USB Full Speed !
sanderman
Newbie level 2
full speed icd2
does this version work with a dsPIC and is debug mode suported as well?
gr sander
browlie
Newbie level 6
icd2 full speed
Does you make the offset film with the cypress CY7C64613-52NC?
silicium81
No, this design ICD2 is for cypress CY7C64613-80NC only !
(for the CY7C64613-52NC, remake a new board !)
Why ?
the cypress CY7C64613-52NC is not find in france !
for the dspic, i don't know...
Patrick
kennylee
Newbie level 3
does anyone know whats the component "FU1" should be? Is it a fuse or other else... Thank you!!
silicium81
FU1 is a small Fuse (500mA is Ok)
Usage: protect your USB port
Best Regards,
Patrick
stroma
hi,
there is no firmware file for CY7C64613 - it is uploaded via USB every time when you connect ICD2. you have to write only corect VID&PID values in eeprom connected to CY7C64613. bin contents of the eeprom may be found in this forum - use search link if you need this
best regards,
stroma
silicium81
I point out that this clone work fine, and that the cy7c64613-80nc is available here: www.radiospares.com (ref: 444-6472 ) :D
Patrick
