scottieman
Full Member level 2
- Joined
- Aug 8, 2005
- Messages
- 136
- Helped
- 12
- Reputation
- 24
- Reaction score
- 1
- Trophy points
- 1,298
- Location
- On Top of Silicon
- Activity points
- 2,658
Dear All,
I need to build a step-up DC-DC converter using push-pull topology. The following link just shows you which topology exactly I am using. (**broken link removed**)
I have read alot of documentation about push-pull converter. However, it seems no one cares about the magnetizing current of the transformer (or the current due to the inductance of transformer).
The following is my problem (please refer to the above link):
When T1 switched on, the secondary side of transformer action forward biased diode D2 and the inductor current iL ramps up. At the same time, the magnetizing inductor is charged through T1 too. When both switches (T1 and T2) are off, the inductor (L) in secondary side is freewheeling with the help of diode D1 and D2.
However, where DOES the current of magnetizing inductor go?? CAN anyone helps me to understand this issue.
Thanks alot
Scottie
Thanks alot
Scottie
