Low frequency VCO implementation in digital and analog
fanshuo
Full Member level 5
Netherlands
I want to implement an array pf VCOs . whose frequencies are ranging from -100KHz to 100KHz with a step size of 5(or10) KHz.
can anybody gives some idea on the pros and cons of implementation in digital v.s analog( or refer me relevant documents on this subject is also highly appreciated)
especially from the aspects of power consumption, complexity and accuracy.
Thanks very much.
Re: low frequency VCO
hi
i think you can use divider to increase the freq. resolution, and the freq step can be realized by adding or removing capacitors.
good luck.
jeff
low frequency VCO
Thanks jeff,
But I still need more general comparisons between those two techniques since I am not very familiar with the digital implementations
low frequency VCO
u said from -100 Khz
what is it ?
khouly
low frequency VCO
Thanks Khouly. i should say "centered at 1MHz and in the range of 900KHz to 1.1MHz"
low frequency VCO
then u want it , in IC level , or circuit level "board"
khouly
go for ring oscillator
low frequency VCO
to Khouly, It should be implemented in IC level.
to replyanil, LC oscillator would not be practical for integration.But would a DCO be better?
low frequency VCO
for this small , frequency , u can make it ring , and after it s nice divider , and the ring oscillator is current controller this is a good approach
LC for sure wouldn't be pratical
khouly
low frequency VCO
and how about using digital oscillator?
It might be better for mismatch. But I am not very clear about the power consumption.
low frequency VCO
what do u mean by digital oscillator , is it a DDS
khouly
low frequency VCO
is DDS short for direct digital synthesizer?
I think that is what I mean.
low frequency VCO
yeah DDS ,is direct digital Synthesizer
it can be used as well , specially the DAC can be used and the reqirment is very relaxed .
khouly
low frequency VCO
well, then the question is back to which one is better?
If the first priority gives to the low-power design
Will you system has a XTAL as refrence clock? if you have a XTAL, PLL can help you realize the 5/10K step size. A simple RC relaxation oscillator will work.
low frequency VCO
the ring oscillator will need a PLL to control the frequqncy , which will be fine , the DDS is used in very fine and agile systems
so u can use ring oscillator in a PLL to get use reqirents
khouly
    fanshuo
low frequency VCO
Thanks for your input.
They are very helpful
