all what u need is a dejan inetrface like jtag for flashing , an mbus cable to claculate faid , change imei , some tests ,some free softs & firmware flashes
all of hardware can be self made
all info can be found in **broken link removed** & am ready for any help
kind regards
Hi. I used a normal FBUS/MBUS cable for, flashing, removing locks and changing IMEI. I build this cable and used succesfully with every Nokia DCT3.
The link in the previous post seems to be one of the most reliable. Take a look at https://nokiafree.org/forums/index.php : definitely the best for Nokia phones.
Regards
FUlcro
in dct-3 phones it is possible to change and rebuiled imei but in dct-4 & wd2 you can not able to change imei bcoz in these models imei store in two fiedes 1- in flash ic 2- in the otp memory inside power supply ic that called uem ... if you want to change imei number first must be change uem ( new one ) and after that can write the otp memory and the nokia last models(bb5) it is inpossible to change imei remeber that in dct-3 &wd2can change imei by replacing new uem but in bb5 till now nobody can do that .
here is th hex & schematics for two boxs for flashing motorolla mobile phone.
and also you can find free software for flashing and about interface just you need
a simple usb cable (a to b) .
