beh i m looking for a report generated by primetime that show the size of memory used during simulation for example, the performance of CPU (if it s used for example in 100% or not), everything that can be reported about the materiel ressources used by primetime.
thanks.
I am not sure which version of Primetime are you using, but in the latest version (right now in the releasing process) . synopsys introduced such a feature. May be that will help you. But in the mean time you can check the logfile of the Primetime output. There you can find out the details.
First of all I am sorry for late message. Some how I have missed your last message.
I am not sure the way you are calling PT .. but I can see in my log file something like this..
Timing updates: 1 (0 implicit, 1 explicit) (0 incremental, 1 full)
Noise updates: 0 (0 implicit, 0 explicit) (0 incremental, 0 full) Maximum memory usage for this session: 671.53 MB CPU usage for this session: 836 seconds Elapsed time for this session: 872 seconds
Diagnostics summary: 1 warning, 30 informationals
Thank you for using pt_shell!
Just check you log file once again. nad let me know if you face problem .. then I will try to find out the command in the PT shell because I guess there is a command exist for checking this information.
