abti
Junior Member level 1
planar log periodic tooth antenna
i have to simulate a log periodic triangular tooth antenna. The reference i have was designed to work for a frequency range from 3 to 11.6GHz. i have to simulate an antenna for a range from 100 to 300GHZ. obviously i have to scale down the geometry but which variables exactly should i change so that the result is the same at the new frequency range? should i just scale down the radii and leave all the angles as well as the tao and sigma the same ?
thanks
thanks
